Internet Explorer - web addresses history
- Internet Explorer - web addresses history
20-09-2008 1:50 PM
In this, the latest of several problems I have asked for help with, I am having problems with Internet Explorer.
On the Internet Explorer page, at the top where the web address is typed, there is (or used to be) a dropdown list of the web addresses I have accessed recently. For some unknown reason, it has been cleared of these addresses, and doesn't seem to want to remember anything before today.
Could I have wiped this memory accidently, such as using delete commands on the wrong directories/files? Is there some setup that affects whether previous addresses are remembered or not?
In Control Panel, there is under Internet Options, a thing about how long the history of your web usage is remembered. I have got that set to 20 days.
Thanks for any help offered.
4 REPLIES 4
Re: Internet Explorer - web addresses history
20-09-2008 3:11 PM
Use Firefox
However using IE7 this is how to check your settings
20-09-2008 8:36 PM
Thankyou, OldJim
20-09-2008 11:50 PM
Spybot and some adaware type prog delete the history as it could be a security risk(very small but you dont want the wife knowing what you have been looking at). If you have used one of these it may have cleared it
24-09-2008 4:51 PM
Thanks OldJim and Samuria
