Internet Explorer 9
- Re: Internet Explorer 9
Internet Explorer 9
20-09-2010 12:15 PM
Why would I be worried (I use Firefox)
Quote "The web browsers of the day weren't taking advantage of the power of the hardware, really only about 10%, skimming the surface of the power of a PC," Tami Reller, corporate vice president of Windows, told BBC News.
"We wanted to make sure we're using 100% of the PC to bring the best experience possible."
20-09-2010 4:08 PM
20-09-2010 5:51 PM
20-09-2010 6:27 PM
20-09-2010 6:43 PM
20-09-2010 8:45 PM
20-09-2010 10:17 PM
Quote from: MrT I've just installed Firefox. First impressions - much faster than IE8 with no loss of functionality.
Hmm - might have to give it a try again then - has the SHIFT+ENTER functionality been added so that when you start typing in an URL you can simply hit SHIFT+ENTER once the site you want appears at the top of the dropdown? That's an amazingly good function that seemed to be missing from everything except IE8
20-09-2010 11:18 PM
Which is better.
21-09-2010 9:17 AM
24-09-2010 1:35 AM
Tried others but Firefox has a nice layout and the tabs was great - shame IE took a long time to catch up but the world is changing and MS can't/won't dominate like it used to.
24-09-2010 8:25 AM
24-09-2010 9:01 AM
24-09-2010 1:10 PM
Quote "We wanted to make sure we're using 100% of the PC to bring the best experience possible."
So does this mean that IE9 will be a resource hog, and they are trying to make it sound like a good thing?
24-09-2010 1:19 PM
I installed IE9 on my Windows 7 x64 machine last week and after a reboot Windows Explorer was completely FUBAR. If I tried opening an Explorer window (Control Panel, My Computer, Documents, Libraries etc.) then Explorer crashed and restarted itself. The minute I uninstalled IE9, the problem went away.
24-09-2010 2:55 PM
