Internet Explorer 10
Mav
Fixes: 515
Seems it is now available for download for both Windows 7 & 8.
But be careful as, according to here it installs KB2670838 which can cause some issues with FF and IE on W7 machines (see Platform Update for Windows (KB2670838).
Forum Moderator and Customer
11 REPLIES 11
CX
Re: Internet Explorer 10
edit: removed comment as it wasn't an IE10 bug.
JamesM
I installed IE 10 on win 7 64 bit last week, a few concerns for me were hundreds of inbound and outbound TCP Fin scans in my router log, and it also installed an eye where I put my router password in, if I clicked on the eye icon it changed the star symbols to reveal the password. Not a big deal but it spooked me a bit until I uninstalled KB2670838 which put me back to IE 9. No more TCP Fin scans (touch wood) and the eye has disappeared.
Edit
Using IE 10 I saw no difference whatsoever from IE 9.
VileReynard
Fixes: 20
Get ready to install the various forthcoming patches to the software.
You'd think Microsoft could write a browser by now.
HPsauce
I've now installed the Platform Update and IE10 on a little-used W7x32 laptop.
No problems so far, but I'll hold off on my main W7x64 desktop for now.
Oldjim
Resting Legend
Fixes: 63
I have just hidden both updates - thanks for the tip
drj
I've been using IE10 for two months - very good. Seems very fast and now importantly has spell-checking built in. The only problem I have is the address bar is very narrow being to the left of the tabs.
NedLudd
Right click in the toolbars and select 'Show tabs on a separate row'!
No problems at all with IE10.  Smiley
Geoff,
York.
drj
Doesn't anyone know how to access the spellchecking settings in IE10 please - I want it to check words in capitals which it isn't doing at present
HPsauce
drj
Thanks - but I can't see anything there to resolve my query (unless the page is different when I look at it in IE10 - I'm on IE8 at home)
I posted here because the Microsoft Help for IE10 appears to be completely hopeless.
HPsauce
Hopeless indeed.  Sad
Spelling correction is in the Add-ons section but there only appear to be language selections there (and an on/off switch). You can add words to the dictionary "on the fly" if they're highlighted as bad spelling.
