Internet Explorer 10
- Re: Internet Explorer 10
03-03-2013 6:30 AM
But be careful as, according to here it installs KB2670838 which can cause some issues with FF and IE on W7 machines (see Platform Update for Windows (KB2670838).
Forum Moderator and Customer
04-03-2013 5:19 PM
05-03-2013 6:53 PM
Edit
Using IE 10 I saw no difference whatsoever from IE 9.
09-03-2013 12:11 AM
You'd think Microsoft could write a browser by now.
09-03-2013 9:46 AM
No problems so far, but I'll hold off on my main W7x64 desktop for now.
12-03-2013 6:58 PM
14-03-2013 10:57 PM
15-03-2013 11:58 AM
No problems at all with IE10.
York.
18-04-2013 7:06 PM
18-04-2013 7:45 PM
19-04-2013 7:48 AM
I posted here because the Microsoft Help for IE10 appears to be completely hopeless.
19-04-2013 8:57 AM
Spelling correction is in the Add-ons section but there only appear to be language selections there (and an on/off switch). You can add words to the dictionary "on the fly" if they're highlighted as bad spelling.
