Interesting addon for Microsoft Office - in my case Office 2003
Fixes: 62
http://office-tabs.com/download.htm
I looked for this because I was getting sick of having to go to Window in the menu bar to view a second spreadsheet and worse still clicking on the top right hand cross and instead of just closing the one I was viewing it closed the lot.
The result for me is the following
Fixes: 188
Re: Interesting addon for Microsoft Office - in my case Office 2003
Cheers Jim Smiley
Customer and Forum Moderator. Windows 10 Firefox 64.0 (64-bit)
BryanP
Downloaded and using. Thanks Jim
Fixes: 25
Thanks Jim.  This should be a real boon.
MrT
One of the best MS Office addons ever! Thanks for finding that one!
Fixes: 12
Great find Jim.  I'll be using it. Cheesy
Maurice
drj
Thanks - I've installed it because I'm always completely closing down Excel by mistake when just trying to close one file.
198kHz
Aspiring Champion
Fixes: 13
Like it.  Smiley
Thanks for that, Jim.
Remember you are unique - just like everyone else
BryanP
Quote from: BryanP
Anybody know of anything similar for use with Adobe reader
Fixes: 62
Not sure what the problem is as I don't use Adobe reader but PDF-Xchange Viewer already uses tabs and has a few other features which Adobe doesn't have
BryanP
Many Thanks
I'll try it
Brilliant app in Excel. But couldn't get it to work in Word.
(they're both from the same edition of MS Office)
Infinity
Seasoned Pro
Control+Tab switches between open Excel Spreadsheets, when opened in separate windows.
Which is how I open recent / new  spreadsheets in Excel 2008 v 12.3.3
Fixes: 25
Quote from: PlusComUK
But if you have five spreadsheets open at a time you don't want to go through spreadsheets 2,3 & 4 to get from 1 to 5.  Tabs are much easier.
Infinity
Seasoned Pro
I don't use tabs.
What I normally do though, is slightly displace each window, so I just click on the relevant window to switch between them.
