Intel vs AMD CPUs?
- Intel vs AMD CPUs?
- « Previous
- 1
- 2
- Next »
Re: Intel vs AMD CPUs?
24-02-2017 8:40 PM
Re my earlier post Has no one a comment?
24-02-2017 8:44 PM
@Oldjim wrote:
Going back to the original question
You won't need a separate graphics card so you want a reasonable built in GPU and all the Intel ones have that (I assume AMD have as well although I haven't checked) So the fundamental questions I would consider are
Do you want to run anything earlier than Win 10 as the latest CPU's from AMD and Intel won't
Do you want as quiet a machine as possible - check reported sound levels with included coolers
Look at CPU temperatures with the default cooler - low is better
@Oldjim Not sure what you are saying about earlier than Win10.
Something less than a squadron of jets getting ready for take off, I think!
24-02-2017 9:18 PM
OK - I looked on that site & it doesn't say what the latest CPU is.
So I tried a AMD FX 8350 Black Edition 4.0 GHz processor & there are no problems with running W7 on it.
Perhaps there is a special upgrade for the wealthy?
24-02-2017 9:49 PM - edited 24-02-2017 9:50 PM
All builtin graphics cards are universally poor. A moderate Graphics card can be quite cheap (depending on usage) and won't need special power connections. It also allows you to upgrade without smashing up your motherboard etc.
24-02-2017 10:12 PM
My main computer motherboard has a built-in Intel graphic chip. It also has an AMD Radeon 7850 video card installed in one of the 2 GPU slots. Absolutely no need to smash the motherboard to upgrade. Just add a second card for SLI/Crossfire or replace the 7850 with another card.
And the built in GPU can be disabled in BIOS if need be.
24-02-2017 10:28 PM - edited 24-02-2017 10:28 PM
@SpendLessTime from past performance I would never advise any one for SLI ,,drivers are never any good
24-02-2017 10:45 PM
24-02-2017 10:52 PM
Oh!
That's OK then.
CPU firmware etc is open source and already part of the Linux kernel.
So only Windows users have fight to install drivers.
25-02-2017 12:19 AM
@VileReynard wrote:
Never heard of Linux not working properly on any PC, with the exception of some distros not supporting some 32 bit CPU's.
Doesn't that qualify as "not working properly" then? lol
25-02-2017 12:55 AM
That would be... the exception?
Forum Moderator and Customer
25-02-2017 3:29 PM
Breaking news.
An optimist sees the opportunity in every difficulty.
- « Previous
- 1
- 2
- Next »
