Intel Security Flaw
St3
Aspiring Champion
Fixes: 5
Intel Security Flaw
81 REPLIES 81
rongtw
Fixes: 12
Re: Hope this dont slow down my i7 :(
i think its all Intel chips Sad  MS are sending a update to fix it soon Thumbs_Up
Legend
Fixes: 254
Are you sure, @rongtw? A quick read of the DM article say X86, so maybe X64 systems aren't affected?
TheRoadCrew
Fixes: 9
x86_64 only I believe.
That's where the performance regression is likely to come from
rongtw
Fixes: 12
@jab1  Almost every Intel processor manufactured over the last decade contains a major security flaw that could be exploited in severe attacks. If that isn’t bad enough, patching the issue might slow down the performance of a CPU by up to 35 percent.
Source https://www.techspot.com/news/72550-massive-security-flaw-found-almost-all-intel-cpus.html
Legend
Fixes: 254
OK @rongtw - I stand corrected.Embarrassed
I'll still be interested to see what, if anything happens to performance, some of the articles seem to give themselves plenty of  'wriggle-room' 5-30% is a wide spectrum.
Edit to add: I know there's no detail about this threat, but I wonder how close to your machine an attacker  will have to get, or how they would?
30FTTC06
Fixes: 4
You can get the tool to check if you are indeed vulnerable or not https://downloadcenter.intel.com/download/27150?v=t
St3
Aspiring Champion
Fixes: 5
Status: This system is vulnerable.
Tool Stopped
Knuppel
So i wonder if the MS update also means i may have to update my bios too ?
And if this update does slow our cpu`s down then what are our rights ? I mean i didnt pay for no slow cpu !!
TheRoadCrew
Fixes: 9
That's for a different Intel flaw (though I suppose if you're affected by one it's likely you'll be affected by t'other)
TheRoadCrew
Fixes: 9
Intel Responds to Secuity Research Findings
(AKA PR BS)
VileReynard
Fixes: 20
I always buy AMD.
They are cheaper, faster and apparently more secure! Cheesy
rongtw
Fixes: 12
Could be all chips Now including AMD , ARM Undecided
The issue was originally linked to a flaw only in Intel's chips, but the firm said this was "incorrect".
http://www.bbc.co.uk/news/technology-42561169
Oldjim
Resting Legend
Fixes: 63
uncleadolph
As I understand it the patch will affect all chips irrespective of whether they are Intel, AMD or whatever.
rongtw
Fixes: 12
Microsoft has released an emergency patch this evening for Windows 10 that is being applied automatically. Windows 7 and Windows 8 will receive a patch next Tuesday.
https://www.techspot.com/news/72576-massive-cpu-flaws-get-name-meltdown-spectre-what.html
