Installing video codec on Windows Media Player Vista
- Re: Installing video codec on Windows Media Player...
20-03-2009 10:36 PM
When I try to play a DVD , windows media player says it hasn`t got the video codec to run it. ! (not much of a "media" player.... )
I have googled and found an MPEG2 codec, that is supposed to solve the problem, but HOW do I install it, and WHERE do I install it to. so that WMP will reconise it....
I have installed VLC media player, and it works fine, but I like to have the graphic equalizer working when watching music videos, and I like the way WMP works.... (well it did with my XP, but I can`t remember that far back as to how I got it working ! ! !)
Re: Installing video codec on Windows Media Player Vista
20-03-2009 10:49 PM
Also have a look at http://www.free-codecs.com/download/K_Lite_Codec_Pack.htm
20-03-2009 11:31 PM
Forum Moderator and Customer
21-03-2009 8:30 AM
Thanks for the hint about graphic equalizer on the VLC player.... .. Do you know if you can make "playlists" on VLC? if so how?
21-03-2009 11:49 AM
Never actually used playlists in any music/video app so far, though. I just prefer to leave on random
Edit: You may find something useful here.
22-03-2009 8:12 PM
