Installing extra memory - this might be more complex than it looks!
- Re: Installing extra memory - this might be more c...
21-12-2011 9:19 AM
I have tried it already, and on boot up the POST is often not reporting the correct new RAM size. When it does this, W7 is thrown completely and shows BSODs when it does run (caused by various inconsistent errors, no pattern to it), and when it doesn't W7 just recycles waiting for a diagnostic disc. Taking the new memory out returns everything to normal.
Yes, I have had the memory exchanged. It was tested and found to be ok, but the exchange memory is still showing the same problem so I doubt it is also faulty.
Trawling round the web has thrown up various references to the BIOS having to create a memory map when the memory is first installed. This is kept until it is remade, and it appears that what might be happening is that W7 wants to use all the available memory, but when the BIOS is failing to detect it, there is obviously a mismatch and problems arise. The stock answer is to force the memory map to be remade. This particular motherboard doesn't have a "remap memory" option, so I suppose the obvious way is to shut down, install the extra memory, reset the BIOS by inverting the BIOS battery, reboot and reset the BIOS options.
I've upgraded memory many times in the past by simply inserting it and rebooting, but this is the first time I've ever come across anything like this. Has anyone else had this experience? All replies gratefully received! I'm reluctant to proceed as the current setup is working fine.
No broke, no fix!
Re: Installing extra memory - this might be more complex than it looks!
21-12-2011 9:40 AM
A quick google and the slots are colour coded blue/orange so one each of the pair should be in neighboring slots
21-12-2011 9:48 AM
Quote from: nozzer reset the BIOS by inverting the BIOS battery, reboot and reset the BIOS options.
That, to me sounds highly inadvisable. Usually there are two pins on the motherboard that are temporarily shorted with a jumper to reset the BIOS to default.
21-12-2011 10:26 AM
Quote from: Gus You have to have Matched pairs of DIMM's hence the BSOD's, think of it as 6 slots of 3 Pairs not 6 slots of singles. So take one of your current DIMM's out and fit 2 of the new ones and check.
It's triple channel memory, and there are three matched sticks in each channel. Won't work with just two in.
21-12-2011 10:30 AM
Wow. I'm so out of touch with PC hardware nowdays 😕
Ex-Broadband Service Manager
21-12-2011 10:33 AM
Quote from: nozzer I want to install the new memory sticks (which are identical make, size and type)
If that is true then there should not be any problems. If you read your manual http://support.asus.com/Download.aspx?SLanguage=en&m=Rampage+II+Extreme&p=1&s=29 it says (Page 2-16): "Always install DIMMs with the same CAS latency" so even quite a subtle difference between the DIMMs could cause problems. Also, by and large, the recommendation is NOT to install in pairs (see Page 2-15).
21-12-2011 10:37 AM
Quote from: nozzer there are three matched sticks in each channel. Won't work with just two in.
Yes it will (according to your manual P2-15). Two, three four and six memory sticks are viable configurations.
21-12-2011 10:43 AM
21-12-2011 10:48 AM
21-12-2011 10:55 AM
21-12-2011 11:03 AM
Just doing a BIOS update to see if that makes any difference. There's nothing in the BIOS release notes to say that it should.
21-12-2011 11:14 AM
"For system stability, use a more efficient memory cooling system to support a full memory load (6 DIMMs) or overclocking condition".
Does that mean: "Full memory load (6 DIMMs) does not give you a stable system unless you take extra precautions"?
21-12-2011 12:08 PM
21-12-2011 12:28 PM
BIOS with a patch required to install a "memory recheck" feature, whatever that is.
Thanks for all your help folks...
21-12-2011 1:18 PM
Quote from: Strat
@Strat... I got that idea from here. 1min 25sec...
