Installing a Zip file onto android device
- Re: Installing a Zip file onto android device
03-11-2014 8:51 PM
Please can someone advise me how to manually install an app to Android that is a Zip file?
There is no .APK in the file.
It is the FON App
NE
It is the FON App
NE
Ex Plusnet Fibre customer. Sky Ultrafast (G.Fast) Customer using a Sky Hub 4.2. If you wish to say thanks, please click the thumbs up
2 REPLIES 2
03-11-2014 10:01 PM
A quick google comes up with this hit......
http://androidforums.com/android-lounge/479675-installation-applications-in-zip-format.html
I've not tried it myself
03-11-2014 11:27 PM
It worked - I mustn't have put the right context into Google search
NE
NE
