Installing Linux Mint (XFCE 7.2)
- Re: Installing Linux Mint (XFCE 7.2)
02-12-2015 3:21 PM
It's a Toshiba Netbook NB250, if that helps.
02-12-2015 3:39 PM
Is the pc a normal one or does it use secure boot?
Try "burning" to a usb disk/stick.
02-12-2015 3:50 PM
Not to sure what a 'secure boot' is.
Mmm, I'd need to look around for a spare one.
02-12-2015 3:53 PM
Might just be a bad burn, try re-burning at a slow speed or on a rw disk.
02-12-2015 4:02 PM
Looks like it could be a 'bad burn' as you say. I'll move the ISO to the Netbook and burn it from there.
Thanks.
02-12-2015 4:30 PM
02-12-2015 4:41 PM
02-12-2015 4:49 PM
https://unetbootin.github.io/
Useful for trying out Live distributions without installing them as well
03-12-2015 4:46 PM
03-12-2015 4:52 PM
I've still not fixed this yet as it's for my own project, so only doing it when I have free time.
But I'll change the boot priority as I assume you're suggesting and see what that brings.
03-12-2015 4:59 PM
03-12-2015 5:03 PM
01-01-2016 7:32 AM
01-01-2016 8:19 AM
For backup purposes I boot Mint 16 as a live DVD on a UEFI machine from a bluray reader (explanation available on demand...).
I have two GPT hard disks and GRUB handles everything perfectly well - I can access my hard disks from the live "installation".
02-01-2016 10:30 AM
