Ink Cartridges advice please
the_groundsman
Can anyone recommend a good supplier of print cartridges. I've used an online firm that have been a bit hit and miss. The last order I put in for a replacement black HP cartridge (not an original but "HP Compatible"") was supposed to have 24mls or 4 times the normal capacity but it has hardly lasted at all (feels like less than the normal capacity).  As it only cost £9.95 I'm not that bothered
I've also had a dud that the supplier replaced without a problem.
It feels like  the supplier is not that reliable and so I wouldn't really recommend them
I occassionaly print a few photos but generally its text attachments and the kids homework.
Does anyone have a strong recommendation and do you buy original or "compatible"
barky
Re: Ink Cartridges advice please
I buy from InkFactory.com & would never consider original cartridges .... they are just a waste of money priced high to compensate the printer maker for selling printers at low prices.
I usually but Jettec cartridges - brand new compatibles, not refills - which usually have extra capacity as standard
I have noticed however that HP cartridges tend to be refills or originals most of the time  Sad
I buy original cartridges, but then that's partly because my printer's somewhat specialist - there's no way I'd be able to afford to replace it if compatible cartridges caused damage to the print head, which is built-in to the printer (damage can happen - it's not just scaremongering by printer manufacturers). Having said that, as far as I'm aware all HP printers have the print head built in to the cartridge, so that's not a concern. Seeing as I never buy non-original cartridges I can't advise where to buy them, but for originals, I normally end up buying from oyyy.co.uk - they do charge a few quid for delivery, but their cartridge prices tend to be cheap enough that if you're ordering a couple or more cartridges you still save money despite the postage.
Fixes: 62
When I had an Epsom I used to buy them from here http://www.valueshop.co.uk/ ; and I was very happy with the Jettec alternatives.
I have a Canon now so that isn't an option so I buy the originals from Amazon Marketplace as that seems to be the cheapest
jazz
I use www.justinkandpaper.com/ and find them very reliable and competitive (very quick delivery too even thought they are based in Guernsey)
198kHz
All Star
Fixes: 10
For my Epson originals I've found no-one to beat http://www.mx2.co.uk - as long as you don't mind waiting up to a week.
WYSIWYG - P&P inclusive on everything - no minimum.
Remember you are unique - just like everyone else
Fixes: 62
I am always on the lookout for cheaper cartridges for my canon but MX2 are about £2 per cartridge more expensive than Amazon.
This didn't use to be the case but for original cartridges Amazon will take some beating given their latest pricing
Fixes: 10
A couple more to try:
http://www.cartex.co.uk/cgi-bin/home.asp?r=1
http://www.printcartridge.net/
(I've not used either recently as there is a local shop which is fairly cheap http://www.clarkesonline.co.uk/jsp/clarks.jsp)
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
198kHz
All Star
Fixes: 10
Quote from: Oldjim
...but for original cartridges Amazon will take some beating given their latest pricing
Thanks for that Jim - currently Amazon are undercutting MX2 by about a pound for my Epson cartridges. Maybe they still will be when I next need another - which will be some months hence, as the Stylus Photo 1400 is extremely miserly with ink.  Smiley
juliasdream
Quote from: Oldjim
Just in case this helps Lidl are currently doing a range of Canon cartridges at £2.99 each
I just bought a set of 5 for my Canon iP4600
Unfortunately store like Lidl or Aldi don't regularly re-stock so grab it while you can
juliasdream
Quote from: the
Try http://www.pcfuel.co.uk/
I found them very helpful and will replace duds
Hi folks,
Just back from hols and thought that I may be permitted to give my supplier for canon i905 BC16 carts. £13 ea originals in local shop, £9.70 from supplier and only £2.92 for compatibles which appear to be just as good !!! They also supply all sorts of useful gear  very resonably. Delivery usually next day First Class Post. www.premier-ink.co.uk will find full lists.
colintivy  Cheesy
Fixes: 62
I didn't know Jettec had got round the Canon chip problem - thanks for the information
Always used to use orig in my Canon Ip4500, but once tried InkCycles compatables, and have not been disapointed.
www.inkcycle.co.uk. ; They let you return your empties for credits as well.
Interested
My HP printer cost £20.
My ink costs around £10 - £14 per cartridge at staples http://www.staples.co.uk or wiliknsons http://www.wilkinsonplus.com/
HP have finally sorted out the ink levels programme issue with windows vista so should get more warning this time. Previously my ink usually runs out on Sunday afternoon in the middle of an assignment or other paperwork due Monday am!
Sorry for hijacking this thread but any 160gsm inkjet paper supplier at reasonable cost would be apprecaited. So far am looking at a ream costing in the region of £24. Almost 125% of printer cost Crazy
