Initializecommand C000003a
bill
I have Windows XP SP2.
This  "Initializecommand c000003a" in white letters appears during startup but before the Welcome screen appears. It lasts for about 5 seconds. Everything works as normal but since yesterday it has appeared everytime I boot up.
I would be grateful if someone could tell me what this means and if it is anything to worry about. How to get rid of it, too.
Thanks.
              Bill
Re: Initializecommand C000003a
Nothing showing up on google.
Are you sure you have the spelling correct including the spacing between words etc?
VileReynard
All Star
Fixes: 11
Quote from: bill
Just a thought...
Do you have any SCSI drives - especially RAID?
That "Initialize command" would be something issued during drive etc recognition by the SCSI BIOS.
Still very peculiar though...
bill
Quote from: Peter
It appears top left of the screen. White letters on blue background. It displays like this:
                  Initializecommand
                    C000003a
Before this first happened yesterday, I had re-installed Windows Live OneCare which downloaded as upgraded to version 2 with a number of new features. Perhaps it caused the message. Anyway I have uninstalled it and gone back to Norton 360; but the problem remains. Thanks fo the replies sofar.
Bill
And when all else fails, the WinDBG help file actually helps (from the "Bug Checks"->"Bug Check Code Reference" section): " Cause This error can be caused by any part of the disk subsystem, including bad disks, bad or incorrect cables, mixing different ATA-type devices on the same chain, or drives that are not available due to hardware regeneration. It can also be caused by a missing file from the boot partition, or by a driver file that has been disabled from the *Drivers* tab by mistake. "
bill
Quote from: axisofevil
Quote from: bill
Just a thought...
You prompted me too Google for RAID + BIOS+ OneCare.  Found this:
Forgot to post that Windows Live OneCare went through a version change last week ..... is set to RAID in the BIOS and this issue still exists in build 5744.
Still baffled, but I think you've hit the nail on the head and a solution is no doubt forthcoming.Thanks to everyone..
Bill
bill
Instead of getting rid of the Initializecommand problem I soon got myself into deeper mire.  Windows Update decided I needed to download 88 updates (63Mb worth) but then failed to install them. Ended up with five 63Mb downloads all of which failed to install.
So, in despair I did a full system recovery and the multitude of downloads to catch up on the last 18 months all installed perfectly and the InitializeCommand problem has disappeared.
A long old day's work but I'm happy again.
Many thanks for answering my request for help.
Bill
