In Program folder but not Control,...,Add/Remove list.
- In Program folder but not Control,...,Add/Remove l...
18-09-2008 9:58 AM
Re: In Program folder but not Control,...,Add/Remove list.
18-09-2008 10:10 AM
One is that the uninstall didn't remove everything - very common
Second is that some programs only add themselves to the programs folder but don't change the add/remove registry settings so don't show up in the add/remove section.
In either case I just delete the folder
18-09-2008 10:46 AM
BTW does anyone know what a prog called ATS2 relates to. It's in the prog folder and seems to have to do with virus removal. last modified 2005.
18-09-2008 10:52 AM
Maurice
18-09-2008 12:00 PM
18-09-2008 12:44 PM
16774646, ATS1 is a soluble chloroplastic stroma protein and together with ATS2, is involved in phosphatidylglycerol biosynthesis in chloroplasts. ...
18-09-2008 3:07 PM
To modify Frankie Howerd's crone in Up Pompei
Quote from: pierre_pierre .......
.......chloroplastic stroma protein and together with ATS2, is involved in phosphatidylglycerol biosynthesis in chloroplasts. ...
" Err, err, and thrice err"
19-09-2008 12:06 AM
