Imgburn - a warning
Oldjim
Fixes: 63
Imgburn - a warning
Needed to install my normal burning software as the Win 10 included is flaming useless
Despite my best efforts it also installed two unwanted pieces of software and changed the Firefox start page to Yahoo
Fortunately all easily sorted but a nuisance nonetheless
17 REPLIES 17
Browni
Aspiring Hero
Fixes: 60
Re: Imgburn - a warning
Quite a lot of free software has unwanted extras so care should be taken when installing.
At least Imgburn was up front when I tried it and easy enough to not install the extra
have a look at Unchecky
ITWorks
Fixes: 9
This software recently appeared in Computer Active's "Named and Shamed" section for the reasons given above
Oldjim
Fixes: 63
I unticked that one - it was the other two which I couldn't stop
Browni
Aspiring Hero
Fixes: 60
It also depends on where you get the software.
Where possible always download from the creators website, software distribution sites often include their own unwanted extras.
Oldjim
Fixes: 63
I agree and that is why I downloaded from the Imgburn site
The reference above led me to check here https://www.pressreader.com/uk/computer-active-uk/20170607/281797103960637 and it was only the imgburn mirror which included the unwanted rubbishj
Browni
Aspiring Hero
Fixes: 60
Did you look at Unchecky that I linked to above?
Mav
Fixes: 510
I just looked at the imgburn site and selected from their own server and was met with the following:
Easy for some to miss the 'Click here to customize' options.
The next page had a tick which could be deselected for the next piece of software.
Forum Moderator and Customer
Pete11
Seasoned Pro
Fixes: 4
@Browni
I did, and a big thank you for that. Thumbs_Up
A float tip is pleasing in its appearance and even more pleasing in its disappearance.
Growing old is inevitable...But growing up is optional.
Oldjim
Fixes: 63
@Mav and I did Embarrassed
Browni
Aspiring Hero
Fixes: 60
I didn't see the screen that @Mav posted, maybe because my default browser is Pale Moon x64?Huh
Mav
Fixes: 510
@Browni Does the browser matter as my screen-shot was from running the exe file?
Browni
Aspiring Hero
Fixes: 60
@Mav on your screenshot it says that IE & FF will be reconfigured to use Yahoo, my using another browser probably threw it off.
Mav
Fixes: 510
@Browni I understand that but what about the Ultimate Protection bit? That doesn't seem to be browser dependant?
Looks like I would be totally [-Censored-], though, as I have all three browsers mentioned installed (IE, FF and Chrome):Rolleyes:Knuppel
RPMozley
Fixes: 13
Unfortunately Imgburn is one that bucks the trend of safer downloading direct from website. A long while back when I last installed it (or updated) I went with the direct link as per usual but that resulted in "Immunet protect" quarantining the installer as soon as it had been downloaded, so went to the alternate download sites (unfortunately I don't remember which turned out safe, could've been Softpedia or maybe Major Geeks - all back in 2013).
That's RPM to you!!
