Identifying Smileys
Identifying Smileys
I hope this is the right place to post my query.
At home on my Windows XP desktop when I hover over  the smileys when composing a post I get a little message telling me what the smiley is, i.e.grin,angry etc.
On my laptop using Vista this doesn't happen. I simply get a small blank box.
Is there a setting that switches this facility on?  Undecided
pierre_pierre
Re: Identifying Smileys
my netbook Win 7 gives the smiley name when selecting above the compose window, but not with ones in a recieved message
I'm sure one of the computer experts on here will know the answer Smiley
pierre_pierre
if I right click on the smiley, I get this info with view image info for your last one
http://community.plus.net/forum/Smileys/plusnet/smiley.gif
  Cool
and mine shows as
http://community.plus.net/forum/Smileys/plusnet/cool.gif
Fixes: 10
Does this one give a tool tip when you hover over it?  Grin
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Fixes: 247
it does in chrome..
Customer / Moderator / If it helped click the thumb / If it fixed it click 'This fixed my problem'
Fixes: 10
[me=jelv]suspects that someone hasn't looked at how he composed the post! Cheesy[/me]
Fixes: 247
[me=dvorak]knows someone is tired Wink[/me]
Quote from: jelv
No, sorry it doesn't.
Fixes: 10
Odd! Which browser are you using?
Using FF 3.6.22, This is the same as I'm using on the desktop.  Only difference is that the laptop is Vista and the desktop is XP.
Fixes: 63
Hi artmo,
Been doing a bit of googling. I suspect this problem is caused by a profile setting. I'm using FF 6.0.2 (on Vista) so not sure if this works on FF 3.6 but…
If I open a new tab and type about:config in the address box, press enter and promise to be careful I get a list of preferences. Highlighted ones are those which the user has set.
One of the preferences is browser.chrome.toolbar_tips where I have the default setting, which is true and tool-tips work. Is yours user set and false? If it is, right-click the line and select toggle which should change it to true. There doesn't appear to be an "OK" button at the bottom of the page so I assume either the change takes place immediately, or perhaps next time FF is started. Hopefully tool-tips will then appear.
Fingers crossed Tongue
David
David
Win 7 labels some smilies but not others for some reason. Both Cheesy grins OK but no others used in these posts!
C.  Huh
spraxyt, thanks for your reply. Followed your instructions and it was already showing true.  I unchecked it and then rechecked it to true in case but no luck. It is showing default - boolean - true. This seems an odd one.  When I hover over an icon all I get is a small blank box.
James
Quote from: colintivy
C.   Huh
Colin - Jelv is playing with us Smiley
Artmo is reviewing to the icons that you see when you are previewing your post, not the ones in this thread.
