Identifying Smileys
- Identifying Smileys
Identifying Smileys
20-09-2011 4:44 PM
At home on my Windows XP desktop when I hover over the smileys when composing a post I get a little message telling me what the smiley is, i.e.grin,angry etc.
On my laptop using Vista this doesn't happen. I simply get a small blank box.
Is there a setting that switches this facility on?
Re: Identifying Smileys
20-09-2011 8:10 PM
20-09-2011 8:32 PM
20-09-2011 8:39 PM
http://community.plus.net/forum/Smileys/plusnet/smiley.gif
and mine shows as
http://community.plus.net/forum/Smileys/plusnet/cool.gif
20-09-2011 10:43 PM
20-09-2011 11:25 PM
20-09-2011 11:32 PM
20-09-2011 11:34 PM
21-09-2011 1:55 AM
Quote from: jelv Does this one give a tool tip when you hover over it?
No, sorry it doesn't.
21-09-2011 9:09 AM
21-09-2011 11:33 AM
21-09-2011 1:52 PM
Been doing a bit of googling. I suspect this problem is caused by a profile setting. I'm using FF 6.0.2 (on Vista) so not sure if this works on FF 3.6 but…
If I open a new tab and type about:config in the address box, press enter and promise to be careful I get a list of preferences. Highlighted ones are those which the user has set.
One of the preferences is browser.chrome.toolbar_tips where I have the default setting, which is true and tool-tips work. Is yours user set and false? If it is, right-click the line and select toggle which should change it to true. There doesn't appear to be an "OK" button at the bottom of the page so I assume either the change takes place immediately, or perhaps next time FF is started. Hopefully tool-tips will then appear.
Fingers crossed
David
21-09-2011 5:03 PM
C.
21-09-2011 5:22 PM
21-09-2011 5:26 PM
Quote from: colintivy Win 7 labels some smilies but not others for some reason. Both Cheesy grins OK but no others used in these posts!
C.
Colin - Jelv is playing with us
Artmo is reviewing to the icons that you see when you are previewing your post, not the ones in this thread.
