Icon Creator
atbs1
Icon Creator
Can anybody point me in the direction of a free icon creator please?  I want to make some icons from picture that I have.
hadden
Re: Icon Creator
I've used free IcoFX for lots of icons from images.
Fixes: 4
Re: Icon Creator
I seem to remember creating icons using the "Paint" program that comes with all versions of Windows.
I think you create your 32x32 pixel image, and then save it as with a ".ico" file extension (instead of ".bmp")
- that was a long time ago - but worth a try !
atbs1
Re: Icon Creator
Yes, thank you. using paint worked well.
Fixes: 4
Re: Icon Creator
Excellent !    Cool
