IPv6
IPv6
16-03-2011 1:00 PM
Has PN configured there system so that it will now works with IPv6.
7 REPLIES 7
Re: IPv6
16-03-2011 1:03 PM
No, not yet http://community.plus.net/forum/index.php/topic,89019.0.html but you could always join the soon to start trial.
Not sure why you would post this query in Windows software section.
Re: IPv6
16-03-2011 7:31 PM
Windows 7 ultimate 32bit when I do an Ipconfig it shows the result for Ipv6 as "Link-Local FE80 etc.
Does this mean my pc is Ipv6 enabled, and also for that matter the wireless router. linksys wag200g
thanks
thanks
Re: IPv6
16-03-2011 7:43 PM
Windows Is IPV6 Ready but your router Is not.
If life gives you lemons, make lemonade.
Re: IPv6
16-03-2011 7:44 PM
A couple of Google searches will give you all the info you need
Windows 7 and IPv6 = Yes
wag200g IPv6 As you can see, the OP in that thread clearly states his wag200g isn't IPv6 capable... wait a minute... thats you!
Re: IPv6
21-03-2011 9:11 PM
For those of us on XP how does this IPv6 thing get fixed up?
Re: IPv6
21-03-2011 9:15 PM
Already is - from XP SP2
http://www.windowsnetworking.com/articles_tutorials/IPv6-Support-Microsoft-Windows.html
Re: IPv6
21-03-2011 9:20 PM
M$ implementation of IPv6 on XP was half hearted and missing vitial bits.
You can't really use XP on an IPv6 network.
http://ipv6int.net/systems/windows_xp-ipv6.html
