IP settings
GRDsupport
IP settings
I have a problem accessing my website with the message ‘Forbidden You don't have permission to access /index.html on this server.’ on my own server using apache but I can access it from any local browser by typing ‘file:///C:/theofficialitalianjob/index.html’ everything else looks correct and a port scan shows the IP is working OK from godaddy  with a port 80 success from also and all firewall settings are correct for Apache and port 80 along with all the setting in the router like port 80 and the computer LAN IP. The only think I can see is the router TCP/IP default gateway IP address is outside of my local LAN address but I cannot see an option to change this which is what I normally do with a NTL business line and router I have, any help would be appreciated...
2 REPLIES 2
GRDsupport
Re: IP settings
Sorted it was an forward setting on the godaddy website to a different website as I have so many domains on my Apache servers...
Fixes: 1,495
Re: IP settings
Moderators Note
This topic has been moved from ADSL Broadband to Tech Help
