IP Camera
- IP Camera
IP Camera
19-06-2010 12:24 PM
[color=black][color=black][color=black][color=limegreen]Dear all,
Anybody know how to setup a ip camera?
I am using vista home
Camera foscam ip/wireless camera
gateway?
subnet?
dns?
Port?
Do i need static ip, if so what range?
Many thanks
Laila
[Moderator's note by Adie (Adiewoo) removed poll as it was serving no purpose][/color][/color][/color]
gateway?
subnet?
dns?
Port?
Many thanks
Laila
4 REPLIES 4
Re: IP Camera
19-06-2010 5:27 PM
could you post in regular coloured, i.e. black text? i can't read what you've written.
Re: IP Camera
19-06-2010 5:54 PM
OP - read the manual.
is this readable?
is this readable?
Re: IP Camera
19-06-2010 6:44 PM
what the heck is that poll for at the top.
@Fox, just to help try selecting the unreadable and hey bingo on my machine it white on black
Re: IP Camera
21-06-2010 8:44 AM
Quote from: lkhatun gateway?
Same as your PC
Quote from: lkhatun subnet?
Same as your PC
Quote from: lkhatun dns?
Same as your PC
Quote from: lkhatun Port?
Typically you would want port 80 to keep things simple.
The same range as your subnet, however, if you are leaving all the kit on all the time, your router will take care of setting it all up as soon as you connect it to your netwrok.
Quote from: lkhatun Do i need static ip, if so what range?
The part you seem to have omitted is the steps needed to join the IP cam into your wireless network - all the other stuff will be issued by your router once you successfully add it to your network.
