IE9 vs IE11
- IE9 vs IE11
IE9 vs IE11
01-11-2014 9:18 AM
Re: IE9 vs IE11
01-11-2014 9:39 AM
Admittedly I mainly use FF but I use IE for accessing banking and other sites when using PoA for my mother to keep things separate.
IE11 is apparently more secure then 9 and I see no reason not to upgrade.
Forum Moderator and Customer
Re: IE9 vs IE11
01-11-2014 10:16 AM
I tend to leave the technical arguments about the merits or otherwise of different browsers to those who feel more strongly about them than I do. ;).
Re: IE9 vs IE11
01-11-2014 3:02 PM
Re: IE9 vs IE11
01-11-2014 3:09 PM
York.
Re: IE9 vs IE11
05-11-2014 6:20 PM
Re: IE9 vs IE11
06-11-2014 1:28 PM
really annoying with a lot of websites having recently deployed "touch compatibility" that's got open ended code in it and returns errors at a massive rate on desktop......
Re: IE9 vs IE11
06-11-2014 1:58 PM
A bucket with a hole in the bottom and no handle is better than IE6 though.
Re: IE9 vs IE11
06-11-2014 2:06 PM
It seems fine and no update is being forced on me, IE11 is still showing as optional after almost a year......
