IE9 & 10 support being dropped by MS
- IE9 & 10 support being dropped by MS
05-12-2015 3:31 PM
http://www.zdnet.com/article/millions-of-internet-explorer-users-face-patch-security-showdown/?linkI...
This seems to be for older versions IE9 & IE10 to upgrade to IE11
'After January 12th there will be no more patches to protect against drive-by downloads and other browser vulnerabilities'.
Even so, Microsoft Edge is by far from perfect which is why they have included IE11 in Windows 10.
There are the popular alternatives like Mozilla Firefox, Google Chrome and Opera to name a few..
Just a heads up for all legacy IE users.
No problem can be solved from the same level of consciousness that created it.
Albert Einstein
Albert Einstein
6 REPLIES 6
Re: IE9 & 10 support being dropped by MS
05-12-2015 4:04 PM
Microsoft will still be patching the last version of IE available for a particular version of Windows, IE9 on Vista will still get updates for a bit longer.
05-12-2015 9:26 PM
micorsoft dropped mainstream support for vista in 2012, its listed as ending extended OS support in 2017 but from January 12th will no longer be issuing updates for any older than IE11
its worth noting they already dropped mainstream support for windows 7 and will be ceasing extended OS support in 2020,
windows 8 & 8.1 they will drop mainstream support in 2018 and extended support in 2023,
something tells me the wont be supporting anything below IE11 come January regardless of what OS its on
05-12-2015 9:48 PM
'something tells me the wont be supporting anything below IE11 come January regardless of what OS its on'
Well something tells me that once the IE11 upgrade is done on Windows 7, 8 and 8.1, the next wave of UPGRADE to Windows 10 will be thrust down our ADSL/ Fibre.
[you read it here first]
Albert Einstein
Albert Einstein
05-12-2015 9:55 PM
perhaps the something was this in August 2014 http://blogs.msdn.com/b/ie/archive/2014/08/07/stay-up-to-date-with-internet-explorer.aspx
Quote After January 12, 2016, only the most recent version of Internet Explorer available for a supported operating system will receive technical support and security updates. For example, customers using Internet Explorer 8, Internet Explorer 9, or Internet Explorer 10 on Windows 7 SP1 should migrate to Internet Explorer 11 to continue receiving security updates and technical support.
05-12-2015 10:10 PM
Yes, the article did say it was a reminder from Microsoft, with a link to
https://www.microsoft.com/en-us/WindowsForBusiness/End-of-IE-support
which links to
https://support.microsoft.com/en-us/lifecycle#gp/Microsoft-Internet-Explorer
which links to
Quote Beginning January 12, 2016, only the most current version of Internet Explorer available for a supported operating system will receive technical support and security updates, as shown in the table below:
Windows Desktop Operating Systems Internet Explorer Version Windows Vista SP2 Internet Explorer 9 Windows 7 SP1 Internet Explorer 11 Windows 8.1 Update Internet Explorer 11
29-12-2015 12:16 AM
FWIW, I run W7 Pro 64 bit and use IE10
I wanted to update to IE11 but the install keeps failing even via WUP. I tried all the MS suggested solutions & workarounds but none worked, so no idea why it just will not update? Having said that the one thing I did not try was to uninstall IE10..........scratches head, did I even find the uninstall!
So come January the 12th I will switch to Chrome as that is already by secondary/backup browser.
As for W10, I am hanging back from that until I really have to use it..................possibly with a new build later in 2016???
