IE8 v Firefox
lauprewob
IE8 v Firefox
Afternoon all
Can i install Firefox and still have IE8 installed aswell, I cannot seem to remove IE8 from my pc, it is not in add & remove programs in the control panel. I guess i am asking if one will crash or corrupt the other
Cheers All
Fixes: 57
Re: IE8 v Firefox
yes - no problems at all
Fixes: 8
Re: IE8 v Firefox
Agreed no problems - I have difficulty now in remembering where the IE Icon is though Grin
Maurice
lauprewob
Re: IE8 v Firefox
Thanks guys
jwhite
Re: IE8 v Firefox
I think IE may be optional in new (European) versions of Windows, so it must be possible to remove it.  It's probably in the Windows options rather than the list of applications.  That said, it's not a good idea to be without it as many web-sites still don't work that well in Firefox, and some don't work at all.  Look for the IE Tab extension in Firefox for use in these cases.
Fixes: 57
Re: IE8 v Firefox
That didn't happen - it was a suggestion only.
You don't get the option on a Windows 7 install. This is why they are now selling upgrade packs in Europe.
