IE8 released
- Re: IE8 released
IE8 released
20-03-2009 12:41 AM
http://www.microsoft.com/windows/internet-explorer/default.aspx
What do people think?
Re: IE8 released
20-03-2009 9:06 AM
Re: IE8 released
20-03-2009 9:08 AM
Nothing appears to be broken - yet!
Regards .....
Re: IE8 released
20-03-2009 11:07 AM
Re: IE8 released
20-03-2009 12:17 PM
Did anyone else see this message?
Re: IE8 released
20-03-2009 12:26 PM
Re: IE8 released
20-03-2009 12:30 PM
Quote from: techguy Also did so yesterday but it came up with a message it had installed without updates and recommended I visit Windows Update, I rebooted and did so and no updates were available.
Yep, I got exactly the same message and, after checking for updates, there weren't any.
Regards .....
Re: IE8 released
20-03-2009 12:36 PM
@Mal it doesn't offer an install location option (or I didn't see one) so it looks as though its 8 or nothing, MS are pushing it out as a critical security update (probably next patch tuesday)
Re: IE8 released
20-03-2009 7:58 PM
Quote from: mal0z can you easily install it so you can still use IE7 ?
For testing, there's a Virtual PC Hard Disk Image available from Microsoft with IE8.
Re: IE8 released
20-03-2009 11:47 PM
Just having a play wit hit I havent worked out if you can save changes to the page yet
Re: IE8 released
20-03-2009 11:50 PM
I also quite like the fact that it highlights the domain you are in.
