IE7 will not initialise
Luzern
All Star
Un-installed it because I thought it might have to do with probs mentioned in another thread. Subsequently tried to do new install but half way through got alert as per attachment. Did search on "logs" but nothing listed in C:\ windows that appears to relate to IE. and some is in pure gibberish. I've doen  a pic of the search results page.
Help please!
pierre_pierre
Re: IE7 will not initialise
I would think that the top three are the ones you want as they have todays date
Luzern
All Star
Well I defy anyone to tell me what they mean, or what the relationship to IE initialisation is
See screenshots  Cry Cry
ramidoodle
Hiya,
Can u upload the log somewhere and paste the link here so we can look at it?
have you tried to do system restore to a date before the day you've un-installed it?
Luzern
All Star
@  RamiDoodle I posted them above yours as far as Alt>Prt Scrn would allow.
Yes I did as Sys Res this evening.
ramidoodle
yeah, I thought it might be possible read them with a log viewer or analyser.
Anyway, all I can suggest is to re-install SP2 and then install IE7 after you've downloaded both from MS website. a bit risky :S
