IE11? blocking response to search of website. 'Can't display page' error
- IE11? blocking response to search of website. 'Can...
Re: IE11? blocking response to search of website. 'Can't display page' error
07-01-2016 9:00 AM
Easiest way to see your IP address is look at the bottom RH corner of your post. You can only see your own.
To Gateway hop, log into the modem/router and click Disconnect wait about 30 seconds and then click Connect. Your IP address and Gateway should have changed.
09-01-2016 12:03 AM
Your comment on the IP has worried me, and I fear I might have compromised my security. I went through the process of getting a new Lan IP automatically. twice, but it hasn't changed.
What will gateway hopping do for me. Does it flush things and provide a clean sheet for the old problem?
Richard
09-01-2016 12:11 AM
Unless you've opted for a static IP address, each time a new PPP session is established between the router and PlusNet, the router will get a new IP address.
Addresses on your local network will always be something like 192.168.1.x and you have no need to worry about those being known.
09-01-2016 5:13 AM
Whilst posting ones external IP address does not pose a direct security threat, neither does posting your internal one.
A malicious individual can pick any (external) IP address where there will generally be a user on the end, and attempt some form of attack.
Some of those individuals will find it great "fun" to have a go trying to create further problems for those already having an issue of some sort and posting an internal IP address might assist in such a mean quest, but it's not a direct security threat.
27-01-2016 1:26 AM
Anotherone asked if I have blocked anything. I set the relevant ehsni site as a allowed trusted site (I have the firewall set at moderate to high) but still no luck, and I have diabled almost all add-ons in IE11. I briefly disabled Norton, and no luck.
So apart from learning a lot from you people, and wasting your time, I am no nearer a solution.
But thanks
27-01-2016 1:35 AM
27-01-2016 9:24 AM
I'm doubting that this is a browser related issue if a similar problem was seen using an iMac, but the fact that a Refresh then worked is curious (also mentioned in the OP that other browsers were tried). Re-visiting some ideas may be worth trying.
Quote from: omeadhra ....Went through Control Panel and put in alternative DNS server IPs as suggested by PN somewhere. No difference. .....
Which alternate DNS IP addresses did you use? Did you remove the 192.168.1.254 address (the router) from the list when you put in the alternate ones - or at least moved it to the bottom of the "order of use" list? It might be worth re-booting the computer after making those changes and then just checking those settings to be certain it's been implemented. Try that again.
27-01-2016 9:42 AM
27-01-2016 10:20 AM
Quote from: Anotherone The IP address of the site is 194.32.30.8 BUT although I can get to the site using the link (url) from your OP, I cannot get to it (or pages on it) using the IP address. There must be something weird about the way the site is set up and/or the DNS entries on the resolvers you are using that I don't understand.
27-01-2016 10:50 AM
Edit: There's 11 other domains on the same IP as www.ni-environment.gov.uk
Edit 2: And 4 domains hosted by the server running apps.ehsni.gov.uk
PS: The number of domains running on a single server is pretty much unlimited - there's 10's, if not hundred's of thousands domains hosted on 212.159.8.91
27-01-2016 11:38 AM
27-01-2016 12:31 PM
Quote from: omeadhra So apart from learning a lot from you people, and wasting your time, I am no nearer a solution.
You aren't wasting our time
OK jelv, if I've understood you correctly I've done the following -
Added <194.32.30.8 apps.ehsni.gov.uk #testing with no DNS> to the hosts file without the <>
Removed DNS from the LAN (TCP/IP Protocol), cleared all the browser caches and turned off the browser DNS cache as well, rebooted the computer (precautionary) and then gone to http://apps.ehsni.gov.uk/ambit/Disclaimer.aspx
That seemed to work fine and as a further check I couldn't reach any other websites, so that seems to prove that works if I've tested correctly?
27-01-2016 12:55 PM
BTW:
192.168.1.254 TG582
is a useful entry to put in hosts as you can then access the router by name and it show up in tracerts:
Tracing route to ntp.plus.net [212.159.6.10]
over a maximum of 30 hops:
1 <1 ms <1 ms <1 ms TG582 [192.168.1.254]
2 10 ms 9 ms 9 ms lo0.14.central14.pcl-bng01.plus.net [195.166.130.142]
3 10 ms 10 ms 10 ms irb.14.pcl-cr01.plus.net [84.93.249.145]
4 10 ms 11 ms 10 ms po2.pcl-gw01.plus.net [195.166.129.41]
5 10 ms 10 ms 10 ms cdns02.plus.net [212.159.6.10]
Trace complete.
27-01-2016 1:00 PM
10-02-2016 10:41 PM
I can access this site OK on my mobile phone when connected to the mobile phone network (o2). But if I connect my phone to the wifi hotspot from my plusnet router I can't then connect to this site. This behaviour is reproducible on demand.
I also have the same problem accessing this site from any of the other devices (iPad with Safari and PC with IE11) connected to my plusnet router. I have rebooted my router but this made no difference.
Would appreciate it if someoe else (on plusnet) could try to access the https://www.travelex.co.uk website and let me know if it's just me? Have already spoken to a friend using BT broadband, and he can access the site ok.
