IE Stopped working
randpwar
IE Stopped working
Using IE9 on Vista. I've been away from the pc for a few hours and on returning started browsing using IE and keep receiving a 'The webpage is unavailable because you are offline' message. I am, however, able to use Chrome successfully. Any ideas?
7 REPLIES 7
shutter
Fixes: 64
Re: IE Stopped working
Click "File" on top tool bar...... check to see if you have "Work Offline" checked.....
Mav
Fixes: 510
I was going to suggest that but it's not there in 11 so wasn't sure if it was still there in 9.
Forum Moderator and Customer
randpwar
You're both absolutely correct, thank you both..... Smiley Smiley    I have no idea at all how that happened   Huh
TORPC
Its on the bottom toolbar
Mav
Fixes: 510
A further read and it's been removed totally from 11.
randpwar
As a secondary question, should I update to IE11? Is Vista supported ?
Mav
Fixes: 510
From memory I don't think either IE 10 or 11 are supported in Vista.
