IE Fullscreen not right...
7up
Fixes: 17
Hi guys
My internet Explorer has gone weird. When its set to full screen its now a few pixels to the right and down. I've tried resizing and then going back to full screen and it doesn't correct.
Anyone know whats happened here?
Sometimes my statusbar disappears below the taskbar too like in the picture (Yes its ticked in the View menu). In 9 years of being a PC user I've never experienced this.
2 REPLIES 2
thejudge
Re: IE Fullscreen not right...
Not sure if this will work, but seeing as no-one else has ridden to your rescue... Smiley
(I'm assuming this is IE6, by the way)
Open IE and (in 'normal' - that is to say, not Full Screen - mode) drag the borders till you get them where you want them.
Then, holding down the 'Shift' key, click on the 'X' to close the window. Then re-open.
HTH
holdtight
Also holding down ctrl alt & shift after resizing will keep it in place if just shift doesn't
