IDE to SATA
rongtw
Fixes: 12
IDE to SATA
A friend has a  knackerd his PC fried his Motherboard , has bought a lappy to replace it .
Problem is he has files on his HD he needs obviously there is no connection from lappy to his HD , which i have removed .
My PC is all SATA no IDE connection , which is the easiest way to gain access to his HD to put on a USB to transfer to his lappy Smiley
18 REPLIES 18
HPsauce
Re: IDE to SATA
Buy an external USB/IDE adapter or caddy. Cheap as chips.  Wink
VileReynard
Fixes: 20
Re: IDE to SATA
Or how about one of these - bit pricey...
http://www.amazon.co.uk/ADVANCE-IDE-SATA-Two-Way-Adapter/dp/B001IMAVI0/ref=pd_sim_sbs_computers_6?ie...
HPsauce
Re: IDE to SATA
In a laptop?  Crazy
Strat
Fixes: 565
Re: IDE to SATA
I bought one of these 3 years ago and have used it lots of times with various drives.
w23
Fixes: 4
Re: IDE to SATA
Cheap: http://www.amazon.co.uk/Hard-Drive-Caddy-Case-Enclosure/dp/B003MVW2SM/ref=sr_1_2?s=computers&ie=UTF8...
Call me 'w23'
HairyMcbiker
All Star
Fixes: 21
Re: IDE to SATA
You can get a usb to ide cable, with a psu for a few quid from ebay. Or a case as has been suggested, depends on what size the old disk was, and whether they will ever use it again.
Or something like this would probably be more useful.
HPsauce
Re: IDE to SATA
+1
Covers all the angles.  Cool
rongtw
Fixes: 12
Re: IDE to SATA
@Hairy McBiker  that looks useful  Wink
thanks for all the reply's  Cool
Re: IDE to SATA
I remember a couple of years back when I needed a docking station, I looked at the model that 'Hairy McBiker' linked to - as it looked just what I needed.  However, after much research and reading reviews, I discovered that many people found them to be poor quality - because the plastic parts broke after a few uses, or the USB connection became unreliable.
The one I bought was this - Sharkoon QuickPort Combo, and have been very pleased with it !,
I buy hard drives from eBay, probably averaging about one per month, and use this docking station to perform initial tests, surface scans, data wiping, etc - before each drive gets deployed into whatever my current project is.  It is also very useful for backing up any PC, just plug in a bare drive, copy across what you want to archive, then remove the drive and store it safely away from the original machine.
It may also be worth looking at these other models to see if another type better suits your needs - Sharkoon docking stations
Wink
shutter
Fixes: 64
Mav
Fixes: 512
Re: IDE to SATA
Quote from: Hairy
I've got two of those. Well, actually one is SATA/IDE the other is Dual SATA.
Forum Moderator and Customer
shutter
Fixes: 64
Re: IDE to SATA
Hrmph.... cough !... choke.... see my first ebay linky    Cheesy Cheesy
HairyMcbiker
All Star
Fixes: 21
Re: IDE to SATA
Cough cough yourself, I posted it in reply #6  Grin
WTF
Re: IDE to SATA
Quote from: purleigh
I may have misunderstood, but my reading of the original post was that this was essentially a one-off transfer so maybe the quality's not so important, so long as it works once  Undecided
