I want an app that will guide me when walking in cities or towns
tgr
Can anyone recommend an app for an android phone which will guide you around unfamiliar  towns etc when walking as opposed to driving.
Thank you
Gordon
7 REPLIES 7
orbrey
Re: I want an that will guide when walking in cities or towns
Not sure if this is what you're looking for (don't know if there's any town specific apps) but I always use google maps - links in with searches for places, offers walking directions and can also be used to follow yourself around if you turn the GPS on (assuming your phone has GPS).
Hope that helps.
tgr
Re: I want an app that will guide me when walking in cities or towns
thank you Matt i reckon that will be ideal
HPsauce
And of course it works perfectly with Android.  Wink
And probably logs every step back to Googlecentral.  Lips_are_sealed
w23
Fixes: 4
Quote from: Matt
... if you turn the GPS on (assuming your phone has GPS).
AFAIK it doesn't necessarily need GPS as it can often find an approximate position based on 'visible' wi-fi access points.
Call me 'w23'
Mattz0r
If you're running on Android, you can get the "Trip Advisor" app for the appropriate city. I did that when I went to Rome.
http://www.tripadvisor.co.uk/
Helps you find all sorts of wonderful stuff. Hope it helps you like it helped me Smiley
VileReynard
Fixes: 20
Get a map.  Cool
CX
Quote from: Mattz0r
+1
I used this in New York and it was fantastic. Found some nice little eateries.
One benefit is that it can load the full map for offline use before you move away from your wi-fi and/or 3G data.
