I use Chrome with Windows 8.1 having internet problems
- I use Chrome with Windows 8.1 having internet prob...
20-07-2015 10:54 AM
I keep getting the message "Cannot connect with Proxy server", then the computer locks. I have got round this by opting out of proxy server, is this advisable? If not how can I fix the problem please?
4 REPLIES 4
Re: I use Chrome with Windows 8.1 having internet problems
20-07-2015 1:15 PM
You have (or had) a computer virus that corrupted your settings by inserting a proxy server to control your internet usage. First get fid of the virus then see if problems with Chrome remain. I recommend Malwarebytes . This link should invoke a download https://www.malwarebytes.org/mwb-download/ ;
20-07-2015 1:21 PM
could have been a dodgy chrome extension rather than a virus.
20-07-2015 1:37 PM
:)Having followed all the grand help here, many thanks, it seems much better. The only regular problem is when attempting to open super links in Chrome I get the error message "Google Chrome is unresponsive" any ideas as to what I may have done, or should do to fix it. It is annoying to have to copy and paste to get the link opened.
20-07-2015 2:04 PM
Check Chrome is up to date. Click the three lines at the top right ('Customise and Control") then click About.
