I thought Win 10 was supposed to be free
- I thought Win 10 was supposed to be free
03-08-2015 9:04 PM
Can I revert to Win7? I really don't like the layout or the way that programs are 'hidden' or the fact that 'Edge' doesn't import passwords from Firefox.
Just goes to prove the old adage..."If it ain't broke - don't fix it" !
Re: I thought Win 10 was supposed to be free
03-08-2015 9:13 PM
Acrobat was never free but the reader should be https://get.adobe.com/reader/?loc=uk
You have a month to revert to Windows 7.
03-08-2015 9:17 PM
03-08-2015 9:17 PM
03-08-2015 9:18 PM
But you can't edit PDF's in the free Acrobat reader either......
Quote from: doris It opens in Edge browser, but you can't edit it.
I'm not aware of a free PDF editor included with Windows 7 either.
03-08-2015 9:38 PM
03-08-2015 9:39 PM
03-08-2015 10:44 PM
Or maybe you were not using acrobat but an alternative free pdf editor and had that associated with pdf's on Win 7?
The upgrade has broken file associations.
04-08-2015 6:38 AM
04-08-2015 9:04 AM
As an aside, I used to use Foxit for reading as a considerable improvement on the Adobe Reader. However, Foxit got worse and the Adobe Reader improved, so I have switched back. That of course is a personal choice, but you might want to retry the Adobe Reader.
04-08-2015 9:10 AM
One problem is that if it is Acrobat Standard 7 or Acrobat Pro 8 the licensing server is no longer there
07-08-2015 2:36 PM
