I think I found my next router
- I think I found my next router
- « Previous
- 1
- 2
- Next »
Re: I think I found my next router
16-06-2011 1:51 PM
16-06-2011 1:58 PM
But can i use a LAN port as a WAN so i can run it off the OR modem for fibre?
16-06-2011 3:06 PM
16-06-2011 3:16 PM
Apparently DMT may not work, there are contradictory reports, but the noise margin can be adjusted via Telnet or the GUI with the latest firmware in Australia
16-06-2011 3:35 PM
20-06-2011 9:23 PM
Quote from: dvorak Unlike the 7800N it doesn't have gigabit ethernet so not for me..
gigabit ethernet would be overkill for me, my BB varies from less than1Mb/s up to 6Mb/s.
29-06-2011 3:14 PM
29-06-2011 8:24 PM
30-06-2011 11:54 AM
Since i've got a DG384Gv3,DG384GT,585v7,585v8,D-link 2460R & Some huwei thing lol.
10-07-2011 7:38 PM
Have to say so far I am a bit disappointed. It is supposed to be the bee's knees on long lines, but this one is syncing slower at 9db margin than my old DG834Gv3 was at 12db. Any attempt at reducing the margin just leaves it disconnecting every few minutes (see this thread)
My laptop and tablet also won't connect to the wifi. They don't have 'N', and I would have expected the router to recognise this and adjust itself accordingly. I would manually set it to b/g only, but can't see how - the web interface isn't exactly user-friendly.
- « Previous
- 1
- 2
- Next »
