I just bought my first 4k tv
- I just bought my first 4k tv
- « Previous
- 1
- 2
- Next »
Re: I just bought my first 4k tv
27-04-2017 3:26 PM
Do you have a 4K DVR?
27-04-2017 3:41 PM - edited 27-04-2017 3:43 PM
@gleneagles Which soundbar do you have ? I was looking at this one https://www.amazon.co.uk/LG-LAS355B-Channel-Wired-Woofer/dp/B01FMKT42W/ref=sr_1_1?ie=UTF8&qid=149330...
But im not sure about getting one ... i mean are they really worth the extra coin ?
27-04-2017 4:03 PM
if it's just broadcast TV then probably won't make a jot of a difference other than being "louder" than the built-in speakers.
if you watching blu-ray with HD audio then a soundbar will make things sound a bit better, but never going to be anywhere near as good as a proper amp and speakers.
as for this soundbar, at £89 i doubt it's going to blow anyone's socks off.
27-04-2017 4:12 PM
Not if you want them to be noticed, there's an LAS350B in my picture
27-04-2017 4:23 PM
No, it's a fairly old PVR.
LG SH6.
We both need something loud at our age.......but no matter what sound bar you get if actors are whispering or muttering it will still not make what they say clear......only the very young appear to hear that, if you are in that group you do not need a sound bar.
27-04-2017 11:59 PM - edited 28-04-2017 12:01 AM
As I've mentioned before elsewhere purchasing a 4K Blu-ray player can lead to disappointment as many players advertised as 4K don't in fact natively play 4K Blu-ray movies but are standard Blu-ray players with 'up-scaling to near 4K' built in.
The up-scaling built into the 4K TV is usually better.
True native 4K Blu-ray players are currently quite expensive and there aren't many of them....last time I looked but the situation is changing quickly.
- « Previous
- 1
- 2
- Next »
