I just bought my first 4k tv
St3
Aspiring Champion
Fixes: 5
I just got one of these yesterday for £419 on sale http://www.currys.co.uk/gbuk/tv-and-home-entertainment/televisions/televisions/lg-49uh620v-smart-4k-...
I must say it really is epic!
If any of you are thinking about buying a 4k tv then maybe you should consider this one Wink
20 REPLIES 20
rongtw
Fixes: 12
Re: I just bought my first 4k tv
Nice Ste Smiley
jaread83
Fixes: 81
That's a really good price too.
St3
Aspiring Champion
Fixes: 5
To be honest jar my tv died so we needed a new one and it was the best price range for us.
chenks76
All Star
Fixes: 12
i got one just before christmas.
one should note though that it really does make the SD channels look pretty bad.
there's only so much you can do with an already low quality image, and a combination of upscaling and a much larger screen really makes it grim viewing sometimes (especially on fast moving images.. ie sport).
so unless you also have it connected to an extortionate tv subscription in order to get more HD channels it really does mean that most of the channels (which are in SD) look not great at all.
i got a sony 43" 4K TV, but the primary reason for buying was not for 4K but because it was an Android TV device, which mean i could ditch the few other boxes i was using. so now Plex, Youtube, Netflix, Amazon, Kodi, BBC iPlayer are all accessible direct from the TV.
gleneagles
Aspiring Legend
Fixes: 17
We got that very same tv from John Lewis, about £60 more than you paid for it but that includes a 5 year guarantee.
Excellent set, great picture but if we turn on the dvd player, recorder or other accessory even though it is connected by HDMI it does not automatically switch the screen and you have to bring up the menu and select it.
We are born into history and history is born into us.
chenks76
All Star
Fixes: 12
sounds like you don't have HDMI-CEC enabled on the TV.
St3
Aspiring Champion
Fixes: 5
Smiley The only thing we are trying to get used too is the movement.... it feels like people are moving much faster around the screen have any of you noticed that too ?
Browni
Aspiring Hero
Fixes: 53
I have an LG 49UH750V and my Now TV box connected via HDMI will wake the TV and automatically switch to the correct input. There is a setting within the Now TV Box to enable this functionality as well as the one mentioned by @chenks76
gleneagles
Aspiring Legend
Fixes: 17
As you know there is quite an extensive menu on this tv.
I will have another look through the menu to see if I can find that.
Thanks for the tip.
DaveyH
Champion
Fixes: 12
Just so people are aware when digging around in their TV menus...
Rather unhelpfully the various manufacturers use their own branding for HDMI-CEC.
Samsung use Anynet+ for example, Sony use Bravia Sync or Bravia Link, LG use Simplink and Panasonic use Viera Link etc etc
As eludes to, you need to make sure HDMI-CEC (or whatever you're TV manufacture calls it) is enabled on both the TV and the connected devices.
Browni
Aspiring Hero
Fixes: 53
It's in the general menu under SIMPLINK (HDMI-CEC).
Browni
Aspiring Hero
Fixes: 53
Here you are!
gleneagles
Aspiring Legend
Fixes: 17
Well yes it on along with the message about simplink but it does not automatically connect to any additional components other than the sound bar... the sound bar is also LG so it seems that only LG products connect automatically ?
gleneagles
Aspiring Legend
Fixes: 17
The PVR is a Panasonic and I have no idea what setting if any would be needed on a android box H96 Pro.
