I can't access certain websites (MSN, Facebook, BBC, my bank)
kellyfinb
Just bought a Dell Studio laptop with McAfee trial installed automatically - Internet won't load certain websites (MSN, BBC, my bank) and I would appreciate any help anyone can give me. I've tried IE, firefox & Google Chrome - same problem with them all.  I've unistalled mcAfee and tried AVG 8.0 which made it worse so gone back to McAfee.
Windows firewall is OFF, broadband firewall is OFF, I've turned McAfee firewall OFF and still the problem.  It's soooo frustrating.......
23 REPLIES 23
James
Re: I can't access certain websites
If you go into Internet Options (or the Vista equivalent) and then go to the network tab, then LAN settings, does it show any proxy's being used?  If so, can you try removing them?
Also, do you know if you have tried changing the MTU or rWin settings at all?
kellyfinb
Re: I can't access certain websites (MSN, Facebook, BBC, my bank)
No proxy showing in internet options.
Sorry to be thick but I don't know what you mean by MTU or rWIN???
James
That probably means that you haven't changed it Smiley
Did you try rebooting your router once you had disabled your firewall and antivirus software?
kellyfinb
No I didn't - will try it now
kellyfinb
Rebooted router - didn't make any difference  Sad
Fixes: 1,483
what happens if you open a command prompt and try and ping facebook e.g.
C:\Documents and Settings\Adiewoo>ping www.facebook.com
Pinging www.facebook.com [69.63.184.139] with 32 bytes of data:
Reply from 69.63.184.139: bytes=32 time=113ms TTL=247
Reply from 69.63.184.139: bytes=32 time=110ms TTL=247
Reply from 69.63.184.139: bytes=32 time=108ms TTL=247
Ping statistics for 69.63.184.139:
    Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
    Minimum = 108ms, Maximum = 113ms, Average = 109ms
kellyfinb
pinging mail.live.com (207.46.8.121) with 32 bytes of data:
request timed out
request timed out
request timed out
request timed out
Ping statistics for 207.46.8.121:
        Packets: Sent = 4, Received = 0, Lost = 4 (100% loss),
Fixes: 1,483
mail.live.com doesn't seem to respond to ping requests, can you try facebook?
kellyfinb
Tried with facebook - same timed out response
Fixes: 1,483
does it show the same IP address 69.63.184.139
If so can you do a tracert and post the results:
C:\Documents and Settings\Adiewoo>tracert www.facebook.com
Tracing route to www.facebook.com [69.63.184.28]
over a maximum of 30 hops:
  1    2 ms    1 ms    1 ms  192.168.0.1
  2    37 ms    37 ms    42 ms  lo0-plusnet.pcl-ag01.plus.net [195.166.128.27]
  3    34 ms    35 ms    36 ms  gi1-2-803.pcl-gw1.plus.net [84.92.5.57]
  4    37 ms    34 ms    38 ms  te2-2.pte-gw1.plus.net [212.159.0.186]
  5    33 ms    35 ms    38 ms  te2-4.pte-gw2.plus.net [212.159.1.102]
  6    42 ms    38 ms    35 ms  linx.br01.lon1.tfbnw.net [195.66.225.69]
  7  109 ms  107 ms  108 ms  xe-x-x-x.br01.ash1.tfbnw.net [204.15.22.245]
  8  108 ms  111 ms  113 ms  te-9-1.csw01b.ash1.tfbnw.net [204.15.21.216]
  9  113 ms  108 ms  112 ms  www.02.01.ash1.facebook.com [69.63.184.28]
Trace complete.
kellyfinb
Yes it does show the same IP address - Oddly I can now get into facebook and the tracert is below:
Tracing route to www.facebook.com (69.63.184.143)
1C:\Users\Kells>tracert www.facebook.com
Tracing route to www.facebook.com [69.63.184.143]
  1    1 ms    1 ms    1 ms  192.168.2.1
  2    39 ms    42 ms    38 ms  lo0-plusnet.ptn-ag1.plus.net [195.166.128.123]
  3    41 ms    40 ms    39 ms  ge0-0-0-303.ptn-gw01.plus.net [84.92.3.9]
  4    42 ms    39 ms    41 ms  ge1-1-0-32.ptn-gw2.plus.net [195.166.129.12]
  5    38 ms    38 ms    43 ms  te2-2.pte-gw2.plus.net [212.159.1.106]
  6    41 ms    38 ms    39 ms  linx.br01.lon1.tfbnw.net [195.66.225.69]
  7  112 ms  113 ms  116 ms  xe-x-x-x.br01.ash1.tfbnw.net [204.15.22.245]
  8  111 ms  115 ms  113 ms  te-9-1.csw03b.ash1.tfbnw.net [204.15.23.87]
  9  120 ms  117 ms  111 ms  www.11.03.ash1.facebook.com [69.63.184.143]
Trace complete.
I have done another one for bbc.co.uk as that is a website I can't get into and that came back as follows:
C:\Users\Kells>tracert www.bbc.co.uk
Tracing route to www.bbc.net.uk [212.58.253.67]
  2    41 ms    41 ms    51 ms  lo0-plusnet.ptn-ag1.plus.net [195.166.128.123]
  3    43 ms    42 ms    46 ms  ge0-0-0-303.ptn-gw01.plus.net [84.92.3.9]
  4    38 ms    48 ms    37 ms  te2-2.thn-gw1.plus.net [212.159.1.54]
  5    40 ms    46 ms    47 ms  te2-3.thn-gw2.plus.net [212.159.1.58]
  6    41 ms    43 ms    38 ms  rt0.thdo.bbc.co.uk [212.58.239.25]
  7    42 ms    39 ms    37 ms  212.58.238.149
  8    54 ms    47 ms    39 ms  te12-1.hsw1.cwwtf.bbc.co.uk [212.58.239.234]
  9    *        *        *    Request timed out.
10    *        *        *    Request timed out.
11    *        *        *    Request timed out.
12    *        *        *    Request timed out.
13    *        *        *    Request timed out.
14    *        *        *    Request timed out.
15    *        *        *    Request timed out.
16    *        *        *    Request timed out.
17    *        *        *    Request timed out.
18    *        *        *    Request timed out.
19    *        *        *    Request timed out.
20    *        *        *    Request timed out.
21    *        *        *    Request timed out.
22    *        *        *    Request timed out.
23    *        *        *    Request timed out.
24    *        *        *    Request timed out.
25    *        *        *    Request timed out.
26    *        *        *    Request timed out.
27    *        *        *    Request timed out.
28    *        *        *    Request timed out.
29    *        *        *    Request timed out.
30    *        *        *    Request timed out.
Trace complete.
samuria
You dont say how you connect to the internet ie router modem?
What O/S?
can you type ipconfig /all  and post the results  (from start/run/cmd)
kellyfinb
kellyfinb
Here goes....
Hope this is the info you need.  I connect to internet wireless through Belkin Router.
Ipconfig details below:
Microsoft Windows [Version 6.0.6001]
Copyright (c) 2006 Microsoft Corporation.  All rights reserved.
C:\Users\Kells>ipconfig/all
Windows IP Configuration
   Host Name . . . . . . . . . . . . : Kells-PC
