I Need A Cheap Graphics Card OR New Ram( SOLVED )
Steve
Seasoned Pro
As I am having problems with my pc freezing and other weird things, I've tested my ram but that seems OK, Only other thing I can think Of Is my Integrated Graphics Is Knackered, I don't know what type of graphics card to go for though so need some help, I wont be needing a powerful one and here Is the specs for my motherboard
Processor
• Socket LGA775 for Intel Core™ 2 Duo / Pentium® D Processor
• FSB 1333/1066/800/533 MHz
• Support Hyper-Threading Technology
Chipset
• Single chipset: GeForce7050 / 610i (MCP73V)
Memory
• Single-channel DDR2 memory architecture
• 2 x 240-pin DDR DIMM socket support up to 8 GB
• Support DDR2 667/533/400 DDR2 SDRAM
Audio
• Realtek ALC888/1200 8-channel HD Audio codec
• Compliant with HD audio specification
Storage
• Support by NVIDIA GeForce 7050/610I
- 1 x Ultra DMA133/100/66 port
 -4 x Serial ATAII 3.0Gb/s devices
• RAID 0, RAID 1 configuration
Peripheral Interface [Internal/Rear Panel]
1 x 24-pin ATX Power Supply connector
1 x 4-pin ATX 12V connector
1 x FDD connector
1 x IDE connector
4 x Serial ATA connectors
3 x USB 2.0 headers support additional 6 USB ports
1 x Front panel switch/LED header
1 x Front panel audio header
1 x S/PDIF out header, 1 x CD-in header
CPUFAN/SYSFAN connectors
1 x PS/2 keyboard & PS/2 mouse connectors
1 x Serial port (COM1)
1 x VGA port
1 x RJ45 LAN connector
4 x USB ports
1 x Audio port 8 CH 6 JACKS
Expansion Slots
• 1 x PCI Express x1 slot
• 1 x PCI Express x16 slot
• 2 x PCI slots
BIOS
• AMI BIOS with 8Mb SPI ROM
• Supports Plug and Play , ACPI& DMI
• Supports STR(S3)& STD(S4)
Onboard LAN
• Realtek RTL8101E Family PCI-E Fast Ethernet NIC
Video
• On Chip NVIDIA GeForce 7 Series Graphics Processing Unit (GPU)
• Share Memory: Maximum up to 256MB
Form Factor
microATX (9.60 inches by 9.60 inches [244 millimeters by 244 millimeters])
If life gives you lemons, make lemonade.
MrT
Re: I Need A Cheap Graphics Card
Before parting with some pennies, it might be worth re-installing or updating your graphics drivers. Smiley
Fixes: 62
Steve,
The first question is how much memory have you installed and which operating system are you using.
The reason for this question is whether a graphics card with a decent amount of on board memory is preferred
Steve
Seasoned Pro
I am having real bother with my PC, And I can replicate my PC Crashing, I can always get It to crash or freeze when I run experience index test and Its freezing at running direct 3D aero assessment!
2gb of Ram and using windows 7 32 bit, Also my PSU only has an output of 250W.
Steve
Seasoned Pro
Just ran windows own memory diagnostics test and the PC froze doing that, Also just ran Memtest86+ and the PC froze trying to test with that to. Bad ram? Any Ideas?
Fixes: 20
Sounds like bad ram, try reseating them in the holders. Are you running memtest from a Live CD?
Steve
Seasoned Pro
Yeah already tried reseating them a few times but not got me anywhere, Yes was running that of the live CD.
Fixes: 62
Try running on only one stick at a time
Steve
Seasoned Pro
OK I will give that a go Jim.
Fixes: 20
Could also be the psu dropping out, do you have a spare to try?
Steve
Seasoned Pro
No I don't HB but I don't think Its dropping out, How would I be able to tell?
Edit I will report back once I have taken a stick of Ram out, One thing I have learned Is this PC Is bog standard, Not a happy chappy as Its only one year old
Steve
Seasoned Pro
Well I have tried to replicate the complete freeze up again by running the windows experience index test. It has ran twice now, Albeit rather slowly but no crashing or lock ups. Took out a stick of ram Now running windows on just 1GB if that!
Fixes: 62
Re: I Need A Cheap Graphics Card OR New Ram
You should now try the other stick and if that runs OK I suggest backing off the memory timings in the bios and then trying two sticks again
Fixes: 10
Looking at just your processor alone Steve I'd say a 250W PSU is a bit low tbh.
I'm using a 2.8 Celeron with 1Gb Ram  - it's single core and all about 8 years old (so fairly old). Even so I'm using a 400w supply. Might just be worth trying another just in case.
Steve
Seasoned Pro
OK Jim I will try the other stick of ram and report back.
