Hybrid HDD
- Re: Hybrid HDD
Hybrid HDD
08-11-2014 12:15 PM
Thinking of buying one of these http://www.novatech.co.uk/products/components/harddrives-internal/satahybridssddrives/st1000dx001.ht...
Seems to give me the best of both worlds for the new rig -loads of storage but a bit more speed at start up WITHOUT buying an expensive SSD or a small SSD and a bigger SATA HD.
Anyone used one yet? If so, does it improve loading times particularly at start up?
Re: Hybrid HDD
08-11-2014 12:21 PM
http://www.pcworld.com/article/2025402/ssds-vs-hard-drives-vs-hybrids-which-storage-tech-is-right-fo...
I think that this video may answer the questions
Re: Hybrid HDD
08-11-2014 12:31 PM
Personally I'd go for a £35-£40 SSD which should get you around 100-120Gb and use a half decent drive with a good warranty (WD Red ?) for the main storage drive.
Eggs and basket also spring to mind - I'd rather have a few 1TB drives than 1 x 3Tb drive
Re: Hybrid HDD
08-11-2014 12:44 PM
Regarding SSD or Hybrid the programs which take longest to load are games and they probably wouldn't fit into an 8GB SSD along with Windows so as far as I am concerned the advantage would be for Windows load and shut down times but as I use sleep mode it wouldn't be a factor
Re: Hybrid HDD
08-11-2014 12:47 PM
I intend to use an "old" Maxtor 120 GB IDE hard disk in a caddy as a back up for photos ,music etc (not the drive which is failing on the current spare machine!) so I'm willing to take the risk with 1 TB disk.
As to Seagate disks failing -funnily enuf the disk that has (almost) failed is a 80GB WD drive!!
Would really like to hear from someone who is actually using a hybrid drive day to day.; I've ordered the new motherboard,processor and memory and I have liberated a midi tower case and newish PSU -so need to order the new HDD soonish.
Re: Hybrid HDD
08-11-2014 1:24 PM
My Mac has flash storage and so that's even faster. Also an SSD will last a long time (around 8-9 years) and an SSD powered up but never used will last over 100.
They are coming down in price - keep an eye on UKHD also as the odd 512/1TB SSD pops up on there from time to time and silly prices. I missed the last one which was like £89,99 for 512
Re: Hybrid HDD
08-11-2014 11:06 PM
I used a 120GB Mushkin Chronos SSD coupled with a 1TB Western Digital Blue HDD, and that all cost less than £80 (HDD was NOS, so was cheap), works beautifully, all my games go on the HDD, the OS on the SSD, it's a speedy thing for a reasonably old Core2Duo system...
Oh, and avoid Seagate and Samsung drives, Seagate drives have gone down the pot when it comes to reliability, and as they took over Samsung's HDD manufacturing a couple of years back, they've brought those down to their poor level too, WD or Toshiba if reasonably priced are my choices, anything else is just not worth it...
Re: Hybrid HDD
09-11-2014 11:41 AM
Hitachi - expensive but reliable and good warranties
WD - good value, reasonable reliability and more warranty than Seagate
Toshiba - hmmm - still more reliable than Seagate
Samsung - Owned by Seagate but at least it doesn't say it on the drive. Used to be great but no longer .....
Seagate - might as well store your data on a chocolate bar.
Re: Hybrid HDD
09-11-2014 2:51 PM
The others are second-rate.
Although I've got a 2006 Toshiba laptop still running on its original (Toshiba) disk...
Re: Hybrid HDD
11-11-2014 7:55 AM
Re: Hybrid HDD
16-11-2014 1:24 PM
unfortunately the worst drives (and service) I've had in the last few years have been Seagate, all kinds of problems from there service department send out dead drives to replace dead drives to them claiming the replacements weren't available because the drives (that they had just sent as replacements) were outside of warrantee never mind the failure rate being 8 out of 8 within 12 months ...
