Huwae Mobile Dongle & aAndroid tablet
- Huwae Mobile Dongle & aAndroid tablet
22-12-2014 11:48 AM
When plugged into the tablet, there does not seem to be any "set up" or initialising, The dongle has a "Mobi Data" Sim Card inserted... it is flashing blue, about every 4 seconds,....
If I access the WIFI on the tablet, it shows me connected to my plusnet router..... but does not list the Three or 3G network... ( other locals are listed )...
IF I click the + sign... to add network... it asks for a Network SSID... where do I find this ... is it the long number on the SIM card?
When plugged into my laptop, it goes through an "installing device" procedure, and I can connect to the net via it, ( in the same position, so signal is good )...
Should I put the 3 sim card in first ? ( although I am not a "paid up member" of Three to access the net via that company )
Re: Huwae Mobile Dongle & aAndroid tablet
22-12-2014 11:57 AM
Not tried it as I use a mifi device
22-12-2014 12:02 PM
[Edit, just looked at HMcB's link and I see that's using PPP Widget]
22-12-2014 12:12 PM
Going out now for a couple of hours... will get back to you all later....
Thanks...
22-12-2014 4:43 PM
https://www.youtube.com/watch?v=Ohiwi--OiMM
( have not done any "ROOT" stuff, as I am not sure what I am supposed to be doing there..... perhaps I need to find out about that ? ? ? )
I get the following messages on my screen...
unfortunately padphone has stopped working OK
Unfortunately, com.android.server has stopped. OK
NO !... it`s not OK... what can I do about it .. ?
( PPP widget 2, is not compatible with my tablet )... so am using the original PPP widget... (well at least it is installed )...
22-12-2014 5:05 PM
I'd bite the bullet and go out and get yourself a mifi - they are far superior, and more flexible, than a dongle.
22-12-2014 5:48 PM
So... it seems I can`t do any "rootin" around... !...
22-12-2014 6:00 PM
Quote from: Hairy Check out THIS
Is this....
http://www.ebay.co.uk/itm/3G-Mobile-Power-Wireless-MiFi-WiFi-USB-Broadband-Hotspot-Router-Modem-Dong...
The sort of thing you are using ?
Is it "plug n play " ? or is there some "set up" to follow through, before it gets connected.... ( presumably, to the SIM card inserted )...
22-12-2014 6:10 PM
Or just get your tablet rooted.
22-12-2014 6:36 PM
Have you got a "linky" to the tesco one you have ?
22-12-2014 6:55 PM
22-12-2014 6:56 PM
Rooting you tablet is probably quicker and easier than messing about with these. (unless it is a hudl 2)
22-12-2014 6:59 PM
Quote from: pwatson Getting 3G dongles working under Linux was always problematic and I'd expect Android to be more so.
The latest Linux's have no problems with 3g dongles, drivers are included in the kernel & the network connection app can usually connect in a few sec. Unlike a few years ago when you had to install a 3rd party app to do it.
22-12-2014 7:07 PM
Getting one working with my (rooted) Nexus 7 was not easy and didn't work very well with PPP widget. In the end I decided that it was worth the money for a Mifi unit.
22-12-2014 7:17 PM
Support on these Chinese devices is abysmal, so good luck if you buy the ebay one.
