Humax Foxsat HDR
- Humax Foxsat HDR
Humax Foxsat HDR
16-10-2011 2:15 PM
A quick Google reveals this:
Quote E-FE
Definition : Failed Compare After Flash Write
Possible Remedy To Rectify Error : The Flash Memory Of The STB Is Damaged* You Need To Change The Main Board (CPU Board). Return Your STB To The Retailer To Be Replaced.
I just wondered if anyone else had come across this and if there is a quick fix procedure.
I have emailed Humax support and await their reply.
The unit is under 12 months old...until the middle of November this year.
Re: Humax Foxsat HDR
16-10-2011 3:02 PM
Sounds like you may have to return it for repair/replacement.
16-10-2011 4:44 PM
Quote HUMAX MAILER TELE: 0844 669 0677
Freesat software update and new website launched
Dear Humax user,
We are pleased to release the following software update for the
Foxsat-HDR models that resolves the recent issue of having a
delay in scheduling recordings via the EPG.
New software updates
New software updates for all Foxsat-HDR models
Foxsat-HDR models version HPRSFCI 1.00.17 (Broadcast)
Starting: 13/10/2011 @ 11am
New version first time broadcast
To check the full release notes of this update please click here
http://www.humaxdigital.com/uk/support/
For further information please do not hesitate to contact Humax
customer services by email at [email protected] or
on the telephone on 0844 669 8800.
16-10-2011 4:57 PM
16-10-2011 5:50 PM
Humax Update 1.02.20
16-10-2011 6:53 PM
Quote from: Vip3r Have you tried the process for manually updating the flash via USB?http://www.avforums.com/forums/freesat/1517610-media-file-server-bundle-foxsat-hdr-release-4-0-a.html
Yes but take care to use the correct firmware
http://www.humaxdigital.com/uk/support/downloadcenter_model.aspx?category_seq=65
Then, if your box is networked, maybe install the Media & File Server Bundle for the Foxsat HDR by raydon. See:
http://www.avforums.com/forums/freesat/1517610-media-file-server-bundle-foxsat-hdr-release-4-0-a.htm...
martin
16-10-2011 7:41 PM
16-10-2011 7:56 PM
Yes I have but it failed but I will be downloading a fresh copy onto a clean drive and trying again.
It's a pity it won't update direct from a site.
17-10-2011 8:58 AM
17-10-2011 11:24 AM
17-10-2011 11:30 AM
I have an identical unit to my daughters' and have updated mine using the same stick as I used on hers with no problems.
Hopefully Humax support can offer a solution.
17-10-2011 6:40 PM
Humax Support have replied to my email and offered either a repair or exchange. I've requested an exchange.
All good so far
17-10-2011 6:47 PM
17-10-2011 8:33 PM
Quote from: Strat
My daughter has a Foxsat HDR which is showing an error on it's display of E-FE.
Erm..... shouldn`t this be posted in "Hardware.... the place to discus..... " ahem......
17-10-2011 9:16 PM
I expected a Mod to move it
