Hudl SD Card setup?
PeterLoftus
Fixes: 5
Hudl SD Card setup?
I've been given a Hudl 2 for my birthday and first impressions are very favourable
My problem is that I have inserted an SD memory card which the system recognises but how do I use it?
The first thing I wanted to do was download my music using Easyphonesync. It failed when I tried to download the SD card but succeeded to the internal memory
Is there a set up process to make software use the extra memory?
Thanks in advance  Smiley
To do is to be - Neitzsche
To be is to do - Kant
do be do be do - Sinatra
5 REPLIES 5
Mav
Fixes: 518
Re: Hudl SD Card setup?
I have no knowledge of EasyPhoneSync but I do use MyPhoneExplorer on all my Android devices. Works like a dream and you can navigate easily to the internal and external memories.
Forum Moderator and Customer
PeterLoftus
Fixes: 5
Easyphonesync is specific for downloading iTunes on to Android devices  Smiley
Fixes: 585
It looks like most Apps on the Hudl will default to the Internal memory when storing data and that you need to use a File Manger to move the files to the SD , see here http://www.pcadvisor.co.uk/forums/1/tech-helproom/4268920/tesco-hudl-and-app2sd-apps/
shutter
Fixes: 67
Perhaps you could load up your SD card with your music... and run it from the card... ?
Fixes: 585
If you have stuff already on a PC then Airdroid is a useful app. It allows access to the Android device from a web browser and has a File browser ( amongst other things ) that allows transfer of files between the PC and the Android device.
