Hudl Battery
- Hudl Battery
Hudl Battery
28-04-2015 5:46 PM
Re: Hudl Battery
28-04-2015 7:04 PM
The one I played with the battery was stuck well on and the battery is prone to bend.
Still if you're dumping the old battery that's not a problem.
Re: Hudl Battery
28-04-2015 10:03 PM
Re: Hudl Battery
29-04-2015 9:55 AM
Re: Hudl Battery
29-04-2015 10:31 AM
At best a flexible bit of plastic is the only option.
Re: Hudl Battery
29-04-2015 10:36 AM
Quote from: Hairy use a BLUNT knife or similar to ease it out
Don't use anything sharp.
1. you could puncture the Lithium battery bad idea
2. you could puncture the LCD by by hudl.
Re: Hudl Battery
29-04-2015 11:56 AM
Re: Hudl Battery
29-04-2015 10:34 PM
In the end I used a strip of plastic cut from a top up card, or the like, to slide in and help brake the bond. And as suggested a flexible blunt knife.
Though that was mainly because I wasn't chucking the battery.
That is a handy kit though. I bought mine off ebay from China. Cost me some silly price in auction like 11p.
Re: Hudl Battery
30-04-2015 9:24 AM
Re: Hudl Battery
01-05-2015 2:49 PM
Re: Hudl Battery
01-05-2015 11:53 PM
I can see why these often get broken.
Going by the icon on the micro USB plug, it inserts upside down compared to all the other devices I have.
