Hub one useing USB port as a print server.
- Re: Hub one useing USB port as a print server.
31-12-2015 2:06 PM
Does anyone know how to set up the Hub one, so that I can use the usb port for a print server.
2 REPLIES 2
31-12-2015 2:38 PM
I'm not sure this is easily achieved (the Hub One is very similar to the BT Home Hub 5 in many respects).
02-01-2016 10:20 AM
Thanks,
