Hub One as Bridge?
- Re: Hub One as Bridge?
Hub One as Bridge?
22-03-2016 7:30 PM
I saw that it was possible with the 2704n but can't find any relevant info on the Hub One. Apologies if this has been posted before and I've missed it.
22-03-2016 7:45 PM
http://community.plus.net/forum/index.php/topic,147535.msg1304166.html#msg1304166
Unless Reply #1 in that thread helps you.
22-03-2016 8:22 PM
The simplest is just to plug the Hub One into your VDSL line, the use an Ethernet cable from a Lan port of the Hub One, to the Wan port of your router. Let the Hub One do the authentication stuff on the line, switch off Wifi and smart setup, and change the IP range if its the same as your router.
Hope this makes sense, but feel free to ask if you have any questions.
23-03-2016 7:54 PM
I wanted the Hub One to be a bridge to my RT-AC68U as it allows me a load more options like QoS and can't stand how limited the UI is of the Hub One. I've done what you suggested Mustrum and all is well.
Thanks both for your quick responses and help, it's much appreciated.
23-03-2016 8:36 PM
28-02-2017 9:12 PM
I have a Hub One now that I have fibre broadband (to the box in the street) which I'd prefer to set in bridge mode (if possible) to work with my existing Asus DSL-N55U Annex A as the latter provides greater range and flexibility as well as two USB ports. I have been going round and round in circles with both the Asus technicians and Plusnet's without any success whatsoever. The last passing comment by the fairly unhelpful Asus guy was that "it's probably a hardware problem" - most unlike the previous Asus guy I spoke with a couple of years ago about an issue I had. Is this suggestion really going to be that simple to resolve my issue?? I hope so, if not any other ideas???
28-02-2017 9:40 PM
According to Asus your router is VDSL compatible, so you don't need to use the Hub1, just enter your username and password in your Asus router and keep the Hub One as a backup. More info on how to do this on the help pages.
28-02-2017 9:58 PM
no that is a different unit (DSL-AC55U) : https://www.asus.com/uk/Networking/DSL-AC55U/
mine is a DSL-N55U Annex A : https://www.asus.com/uk/Networking/DSLN55U_Annex_A/
.....a different beast
28-02-2017 10:27 PM
Ah, sorry, my bad. Seems yours is ADSL only, cant see a way to connect that to a LAN port on the Hub One.
01-03-2017 12:04 AM
@andymaw11 wrote:
Is it possible to change my new Hub One to be a bridge? I managed it using telnet commands on my old plusnet router
I don't suppose you'd care to share the knowledge? lol
01-03-2017 12:11 AM
