Hub One DC Socket
dougjbarnes1
Hub One DC Socket
I've brought an inline UPS to keep my HubOne & Wifi up during a mains outage.
The Unit comes with a DC extension lead that has a 5.5mm plug with 2.1mm centre hole which is supposed to be the size for my HubOne but the plug won't fit.
Does anyone know what size the centre pin needs to be?
4 REPLIES 4
daviesryan35
Re: Hub One DC Socket
5.5mm pretty sure and it's centre positive.
Fixes: 1,495
Moderators Note
This topic has been moved from Broadband to Tech Help
bill888
Champion
Fixes: 40
External 12V, centre positive, with a 3.0 X 5.5 X 12mm barrel plug.
dougjbarnes1
Thanks, that's what I needed.
