How to stop "Open File - Security Warning"?
- How to stop "Open File - Security Warning"?
26-02-2019 1:01 PM
How can I stop the “Open File - Security Warning” dialog appearing when I click its shortcut on Windows Server 2012 R2?
I know it can be done as I have four machines running the same shortcut, but only 3 of them prompt and I can’t seem to replicate it from the one that doesn't. Needless to say I have searched but the executable in question is being launched from a remote file share.
Re: How to stop "Open File - Security Warning"?
26-02-2019 3:44 PM
Perhaps the first open doesn't point to an open file.
But subsequent ones do?
27-02-2019 9:49 AM
@VileReynard, I don't quite understand what you mean?
When I confirm the action the executable runs as expected, I just don't want or need to be prompted about it at launch.
