How to run web server via ZeroHub?
- How to run web server via ZeroHub?
11-07-2015 11:54 PM
Is it possible to run a web server from home using a ZeroHub?
Clearly the server should have a static ip.
1. How do you allow for this in the ZeroHub? Can you at all? Since there is apparently no access to the DHCP address pool, what's to stop the router assigning your server's ip to another machine and causing a kaffuffle? Do you just shove it up the other end of the address range?
2. How you you set up port forwarding on the ZeroHub? The web server does not appear on the list of port forward targets in the GUI. Proper routers allow ip addresses to be added manually, but there's no provision I can find for this in the ZeroHub.
I'd love to hear from anyone running a public server via a ZeroHub
2 REPLIES 2
Re: How to run web server via ZeroHub?
22-07-2015 1:58 PM
Any ideas anyone? I'm having a lot of trouble accessing my security webcams... (I might have been burgled as I write this!)
22-07-2015 2:20 PM
Found this page http://192.168.1.254/expert_user.html on the router from another thread. It has a method to fix ip addesses on your own network. I've attached a screen shot...
