How to remove some one off your wirless network ?
- How to remove some one off your wirless network ?
19-05-2010 5:26 PM
My brother has found out my password for my wireless and is using the internet he is using all my usage . How to i delet him or remove him , so he can never get back on ?
5 REPLIES 5
Re: How to remove some one off your wirless network ?
19-05-2010 5:35 PM
Change the password and don't tell him the new one. If its a PlusNet TG585v7 router, look at page 27 in the manual. Its the 'WPA-PSK Encryption Key' you want to change. Obviously you will need to change the one on your PC ( if you use wireless ).
19-05-2010 5:37 PM
Use the Access List feature on your wireless router if it allows you too.
3Mb FTTC
3Mb FTTC
19-05-2010 6:31 PM
Also change the default password for you router so he can't use your computer to find it out.
03-07-2010 2:19 PM
WEP is not secure.
Use WPA or WPA2.
Use WPA or WPA2.
05-07-2010 8:53 AM
Assuming he's using his own computer and not one of yours you could block the MAC address (this should be in the Access list that godsell4 mentioned) - just make sure it's not one of the ones for your own PCs and deny it access to the wireless connection.
