How to record a sound file from the radio
shutter
Fixes: 65
Can anyone advise me how to record a sound file from the radio.... and what software to use.
I don`t want to record music, and only need a max of 2 minutes.
I need the sound file to send to a contact in the U.S. via email.
I have a double ended jack lead to connect the REC from the radio to the MIC on the laptop.
21 REPLIES 21
Re: How to record a sound file from the radio
It has been a while since I've used a Microsoft (spit!) operating system, but it always used to have in the [All Programs->Accessories] section, a program called "Sound Recorder".
I would have thought that would make short work of recording a audio sample from the microphone or line input.
shutter
Fixes: 65
I put "sound recorder". into the search box on the start menu, but nowt came up....  Cry
What OS are you running ?
HPsauce
Plenty of free ones around for W7, or use the ones built in to XP or Vista if that's what you're running.
Google is your friend.  Wink
shutter
Fixes: 65
Vista Home Premium
will go away and check out the linkys ......  Undecided
shutter
Fixes: 65
Ah HA !... thanks Purleigh, your first linky gave me a clue.... "soundrecorder" instead of  "sound recorder" in the search box gave me a result....
much appreciated.  Wink
-ap6wqak>
-ap6wqak
If you wanted a few more bells and whistles, then you could download (free) VLC media player - which can record and playback more formats than most other programs.
Smiley
kmilburn
If you want more control, Audacity is a good sound recorder and editor.
shutter
Fixes: 65
Thanks guys... I used to have VLC but rarely used it in favour of GOM player.... ( not sure if that has record ! ! ! ) but will look see, and if not will give VLC a try....
I think Audacity, will be a bit OTT for my application ,  ! ! ..
actually, tried to record some sounds last night with the windows sound recorder, although the cursor moved along as if recording there was no sound on the windows or Irfanview player...
( I know the link cable is good because I use it for other radio/computer applications )
ReedRichards
Seasoned Pro
Fixes: 25
Quote from: shutter
If it is a radio station with a streamed internet option then the alternative is to capture the section of the stream that you want.  I would have thought that would achieve better sound quality.
Strat
Fixes: 565
Quote from: shutter
The microphone input on your laptop may need enabling in Control Panel / Sound / Recording tab where you should also be able to see it in action on a bar-graph.
shutter
Fixes: 65
@ RR ..... no it is not a internet or broadcast station that I want to record.... I want to record some noise !
@Strat.... the mic socket is already enabled, as I mentioned in my brackets previously !  Roll_eyes  ( I know the link cable is good because I use it for other radio/computer applications )  well, not specifically, but the inference is there ! ! ! ...
